Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Arrow Electric Oven
- This topic has 15 replies, 2 voices, and was last updated 20 years, 3 months ago by
fumanchu.
January 4, 2006 at 3:13 pm #14511
fumanchu
ParticipantCan someone help,
the fan oven has stopped working yet the hob & grill are fine. This has happened before where i have been cooking with the oven but for no reason the oven has just lost its heat. Messing with the timer i got the oven to heat up again but this time i cant get any heat from the oven, any sugggestions or thoughts!!!!!!!!!!!!Frustrated
January 4, 2006 at 3:33 pm #159700BobHope
ParticipantRe: Arrow Electric Oven
Hi fumanchu,
model no. would help, its got the letter GB in the middle.ensure the timer is in the manual (hand) position, failing that it most likely to to fan element failure, unplug the appliance before any investigation.
Bob.
January 4, 2006 at 3:47 pm #159701fumanchu
Hi Bob
the model number is A0900 i think
cheers
TonyJanuary 4, 2006 at 3:56 pm #159702BobHope
Hi fumanchu,
dave at spares should pick the info up as i am sure the shop has the element in stock, or email spares@ukwhitegoods.co.uk.
part no teba 10110492Bob.
January 4, 2006 at 4:04 pm #159703fumanchu
will email Dave
thanks for your help, one last point how do i know the timer is set at manual
January 4, 2006 at 5:02 pm #159704BobHope
the timer hand symbol or (M) should be at the top and not the 0 symbol.
Bob.
January 4, 2006 at 5:14 pm #159705fumanchu
the timer is electronic and shows an oven sign above the decimal point of the time, yet when it was working i’m sure the A in the top left corner was showing which only seems to apear when i use the timer
January 4, 2006 at 5:19 pm #159706BobHope
oh i see it that model sorry abt that, 😳 has the clock got 3 or 5 buttons,
Bob.
January 4, 2006 at 5:25 pm #159707fumanchu
5 buttons
January 4, 2006 at 5:33 pm #159708BobHope
please ensure you have set the clock and the display is not flashing,
press and hold the 2nd (cookpot) and 3rd (Stop) buttons from the left together for 2 seconds this cancels any set program and returns the clock to manual mode, the A symbol should not be lit just the cookpot symbol, hope that makes sense. if not drop me a pm with your address and i will send a photocopy to you. 😀Bob
January 4, 2006 at 5:41 pm #159709fumanchu
done that and oven still just blowing cold air, so the part number you gave me is that still correct, if so thanks for your help Bob
January 4, 2006 at 6:12 pm #159710BobHope
so i take it that the fan at the back of the oven is turning but no heat,
if so i will need the full model no. which is located on the top of the oven housing to get the correct part no.removing the oven from the housing is the only way im afraid.
disconnect the oven first.Bob.
January 4, 2006 at 6:39 pm #159711fumanchu
Thats right Bob
the product no.is F09001GB53
January 4, 2006 at 6:43 pm #159712BobHope
correct part no given above.
Bob.
January 4, 2006 at 6:52 pm #159713fumanchu
thats the one i emailed throught to Dave, so hopefully he will be in touch tomnorrow. Is it normal for the air from the fan to escape from a gap above the oven door straight into the kitchen
