Arrow Electric Oven
  • #14511
    fumanchu
    Can someone help,
    the fan oven has stopped working yet the hob & grill are fine. This has happened before where i have been cooking with the oven but for no reason the oven has just lost its heat. Messing with the timer i got the oven to heat up again but this time i cant get any heat from the oven, any sugggestions or thoughts!!!!!!!!!!!!
    Frustrated
    #159700
    BobHope
    Re: Arrow Electric Oven
    Hi fumanchu,
    model no. would help, its got the letter GB in the middle.
    ensure the timer is in the manual (hand) position, failing that it most likely to to fan element failure, unplug the appliance before any investigation.
    Bob.
    #159701
    fumanchu
    Hi Bob
    the model number is A0900 i think
    cheers
    Tony
    #159702
    BobHope
    Hi fumanchu,
    dave at spares should pick the info up as i am sure the shop has the element in stock, or email spares@ukwhitegoods.co.uk.
    part no teba 10110492
    Bob.
    #159703
    fumanchu
    will email Dave
    thanks for your help, one last point how do i know the timer is set at manual
    #159704
    BobHope
    the timer hand symbol or (M) should be at the top and not the 0 symbol.
    Bob.
    #159705
    fumanchu
    the timer is electronic and shows an oven sign above the decimal point of the time, yet when it was working i’m sure the A in the top left corner was showing which only seems to apear when i use the timer
    #159706
    BobHope
    oh i see it that model sorry abt that, 😳 has the clock got 3 or 5 buttons,
    Bob.
    #159707
    fumanchu
    5 buttons
    #159708
    BobHope
    please ensure you have set the clock and the display is not flashing,
    press and hold the 2nd (cookpot) and 3rd (Stop) buttons from the left together for 2 seconds this cancels any set program and returns the clock to manual mode, the A symbol should not be lit just the cookpot symbol, hope that makes sense. if not drop me a pm with your address and i will send a photocopy to you. 😀
    Bob
    #159709
    fumanchu
    done that and oven still just blowing cold air, so the part number you gave me is that still correct, if so thanks for your help Bob
    #159710
    BobHope
    so i take it that the fan at the back of the oven is turning but no heat,
    if so i will need the full model no. which is located on the top of the oven housing to get the correct part no.
    removing the oven from the housing is the only way im afraid.
    disconnect the oven first.
    Bob.
    #159711
    fumanchu
    Thats right Bob
    the product no.is F09001GB53
    #159712
    BobHope
    correct part no given above.
    Bob.
    #159713
    fumanchu
    thats the one i emailed throught to Dave, so hopefully he will be in touch tomnorrow. Is it normal for the air from the fan to escape from a gap above the oven door straight into the kitchen
