Arrow Oven possibly timer problem?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Arrow Oven possibly timer problem?
  • #63200
    natzia
    I have just moved to a new apartment and I have encountered problems with the oven. There is no heating despite the fact that the oven is on. Possibly it has to do with the timer but since I can’t find the instruction manual I don’t know how to fix it. Can someone offer an advice?
    #352953
    Re: Arrow Oven possibly timer problem?
    Arrow no longer exist and haven’t for some time now.
    Do you have a model number?
    natzia
    Sorry I don’t…But if it maybe of some help, there are five buttons. The first one has the symbol of a bell, the second one the symbol of a bowl, the third it has the word stop, the fourth the symbol – and the fifth the symbol +.
    #352955
    natzia
    Does anyone have any ideas? The hob is working though. At the estate agency they told me to play with buttons. A friend of mine tried to help me and he was just pressing buttons and for a while there was heat coming but then he continued pressing buttons and now it’s only cold air.
    #352956
    as Kwatt said arrow no longer exists i think they were sold by B & Q for a while
    you said you talked to the estate agency but you dont say whether its rented or bought. if it rented its your landlords problem to sort it not yours start complaining
    if you own the property then
    if the clock is your problem it can be shorted out by a competant engineer
    i dont know this cooker but is it a fan oven? if so then is the fan inside the oven turning. if the fan is turning then it could be element ( most likely), thermostst or broken wire as normally the fan does not turn if the clock fails
    hope it helps
    natzia
    Thanks so much for your reply. Yes, it is rented property but from the agency they told me to sort it out by myself, just to google it… It is a fan oven, and the fan is turning but only cold air comes out. I have adjust the time and set the timer to zero, and as I said previously when my friend played with the buttons for a while hot air was coming out.
    #352958
    i am sorry but you agancy is wrong
    it is their problem! you rented the house, the oven is part of the fixtures and fittings which you as a tennent expect to be in working order. it is likely the element has failed and the oven would have to be taken apart to effect the repair. If you do it you are effecting the electrical safety of this appliance
    ring your agancy and tell them to get it fixed
    if they dont go to citizens advice they will move their bum then
    i do these jobs all the time for landlords
    An element could prob be got but would need dimentions
