Re: Arsiton A1436
I have had further chance to spend with the machine and by having an opportunity to plug the Merloni Test Module into the diagnostic port F02 was appearing as well as F07. Motor tacho was indicated as well as NTC/ Heater malfunction. Have tried a new motor, did not cure problem, have reflashed the PCB Eprom and recoded, Then showing FO3 !
Have fitted new PCB and reprogrammed PCB and still faulty, turns out the wiring harness between module and motor/heater has breaks in it causing all manner of error codes as above. Awaiting new harness which shopuld be the end to this one. It transpires that Merloni have a service sheet on this very problem. 8)
