Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Artiston Washer Dryer – Margherita
- This topic has 5 replies, 2 voices, and was last updated 20 years, 5 months ago by
SusieDuncs.
November 16, 2005 at 4:13 pm #13365
SusieDuncs
ParticipantI am having major problems with this machine and have done for a long time although this machine is just about 3 years old. Loads of my washing – i.e. t-shirts are coming out of the machine with holes. They are often in the pattern of the drum. Have checked the drum for snags hundreds of times and can’t find anything. Before I pay £89.98 for an engineer to call I thought maybe somebody here could help. Thanks.
November 16, 2005 at 4:40 pm #154520Martin
ParticipantRe: Artiston Washer Dryer – Margherita
Susie,
Overloading is the primary reason for damage to clothing in a machine!
Secondly, the drum on your machine is just slightly thicker than tin foil, so it is prone to damage very easily. The three ‘Drum Paddles’ often loosen and can pinch delicate clothing (especially synthetics).
Finally, don’t waste your money on calling out the manufacturers (far too costly) Instead try Repairs@
November 16, 2005 at 4:44 pm #154521SusieDuncs
Martin wrote:Susie,
Thanks for the advice. Do you know if they do repairs in the north of Scotland?
November 16, 2005 at 4:48 pm #154522Martin
Hit the link in my last post to find out?
November 16, 2005 at 4:52 pm #154523SusieDuncs
Martin wrote:Hit the link in my last post to find out?
Thanks but they’ve not got anyone in this area.
November 16, 2005 at 5:08 pm #154524Martin
OK Susie forget that idea, instead concentrate on checking the drum is clear of any problems. If it is clear, then do please make sure to wash all fabrics on the correct programme. Check their ‘care labels’ and put on the appropriate programme for that label. Also use a quality detergent and not the regular supermarket ‘own brand’ rubbish!
Hope that sorts it for you?…Now go read the User Booklet that came with the machine for the finer points 😉
P.S Use a ‘Laundry Bag’ to wash real delicate stuff in 🙂
