Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Asea Cylinda 1500
- This topic has 7 replies, 4 voices, and was last updated 21 years ago by
fitzmooney.
March 25, 2005 at 8:49 am #8674
fitzmooney
ParticipantIs it possible to get a seal kit and impeller for the above unit?
Asko only want to sell me a pump and motor assembly.
Cheers,
Mike FitzgeraldMarch 25, 2005 at 10:52 am #129940Dave_Conway
ParticipantRe: Asea Cylinda 1500
You wouldn’t happen to have the part number Asko gave you for the whole motor/pump would you Mike ?
I can’t find this model listed, probably as it’s a non UK one.
March 25, 2005 at 3:39 pm #129941Bill
I should think what you want are the following: Support collar seal 80 037 32. seal 80 025 82. impeller 88 007 35. “O” ring 80 025 84 the middle two are exstock others are speicial order.
Bill
March 25, 2005 at 10:45 pm #129942fitzmooney
Hi Dave,
It probably is an Aussie model.
I don’t have a part # from Asko. I had the pump and motor assembly replaced about 5 years ago.
There is a label on the motor housing. looks like it was made in Italy by “IB-MEI S.A.” for Asko. There is a part # 9224335608 on the bottom righthand corner on the label.
I hope this is some help for you.
Cheers,
MikeMarch 25, 2005 at 10:51 pm #129943Dave_Conway
Bill, are those part numbers you gave suitable for this motor by any chance ?
IB-MEI are global so there must be a crossover somewhere 😀
March 25, 2005 at 10:53 pm #129944fitzmooney
Hi Bill,
The seal seems to be made up of two parts.
The spring assembly with a rubber seal at one end and a carbon seal at the other. Then there is a ceramic seat and seal in the pump housing.
The seal has leaked and rusted the shaft which in turn split the impeller.
Hope this is some help.
Cheers,
MikeMarch 31, 2005 at 3:10 am #129945fitzmooney
Hi Dave,
I have managed to get part number for the motor/pump assembly from Asko. It is 8801027.
Also numbers on the machine are –
Type : DM-1500-0262
S/N : 00666
Hope these are of some help.
Cheers,
MikeApril 6, 2005 at 10:34 pm #129946admin
KeymasterRe: Asea Cylinda 1500
Hi,I’m an independant repairer in Australia.
If you have ongoing issues in this forum over the questions you’ve posed then repost as I have many Manuals
- The topic ‘Asea Cylinda 1500’ is closed to new replies.
