Asko Asea 1402
Home Forums Public Support Forums Spare Parts Help Asko Asea 1402
  • #5524
    Is there a fix without replacing the water inlet valve on this machine for the problem:
    Water is cut off prior to correct levels
    #111694
    Re: Asko Asea 1402
    can you elaborate a bit more on that?
    If it is overfilling it is not going to be the valve unless it continues filling even when the machine is not in use.
