Re: Asko d1876 dishwasher error codes ?
Couple of things to bear in mind here, mainly that “Error codes” are not a “magic bullet” to the fix. It’s always worth trying to work out what was happening at the point of failure – was it filling/emptying/heating, for instance. Do you need a code if you find the dishwasher stopped full of water? Logic would suggest a drain failure…… Also, bear in mind that some of the cheap tat we have to work with over here tell lies!
Secondly, the simple act of removing and replacing the connectors on a pcb can clean the contacts and restore circuits. “Wet” appliances suffer from dampness and oxidisation simply from their environment.
