Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Asko fridge freezer KN8526
- This topic has 7 replies, 3 voices, and was last updated 17 years, 4 months ago by
boselecta.
December 3, 2008 at 7:35 pm #41563
boselecta
ParticipantAsko fridge freezer KN8526 sn: 85-101309-525
Fan motor required
I require the freezer evaporator fan motor for this appliance. Cant get the part anywhere, have tried Connect with no luck.
It would be a shame to say goodbye to this appliance as it is only about 8 years old double compressor model, top of the range.
Does anyone know the part no. or where I can get it?
thanksDecember 3, 2008 at 8:09 pm #270600geoff1
ParticipantRe: Asko fridge freezer KN8526
Dont know if this will help
Part number 33213101 and is shown on connect but as obsolete.
Electricalsales.co.uk is where i obtained the part number and are advertising at £25 but do not state if it is in stock
Geoff
December 3, 2008 at 8:18 pm #270601boselecta
Participantwow thanks alot Geoff I will give them a call tommorow mornig, hopefully its in stock then.
alistairDecember 4, 2008 at 5:38 pm #270602boselecta
Participanttoo good to be true. rang them part is now obsolete. Another Asko on the scrap heap because of unobtainable parts.
thanks anywayDecember 4, 2008 at 5:51 pm #270603petalpop
looking at the picture on connections there must be a motor you can get to fit once you have it off the machine and in your hands
December 4, 2008 at 5:59 pm #270604petalpop
take a look at
frg4886
frg5110
or 5031687984234
i put fridge fan motor in the search and there were 412 motors
admitadly quite a few are nothing like it but quite a few are v/similar
it must be worth a lookDecember 4, 2008 at 7:03 pm #270605boselecta
Participantthanks petalpop
I probably could try similar ones but the thought of buying a couple to try, driving to a job 15 miles away, attempting to fit an awkward part only to find the shaft is too long/ short,then have the customer moan that she wont have her appliance before xmas.
For a part job like this I would want to be more than 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} confident of completing with the correct part.December 4, 2008 at 8:39 pm #270606petalpop
quote hir £130 order two or three at around £5 to £10 each
you must end up with one that fits then its a good earner -
