Asko pump?
  • #69469
    Never seen a kosher ASKO before, only in their ISE guise.
    Have a call quite some distance away from a customer with a W6021. (not sure about that number)
    She is certain the drain pump has failed. Will the same pump that fits the ISE fit this machine or is it one of the seriously expensive ones shown in the ‘Store’ here?
    Re: Asko pump?
    This one Jim…
    http://shop.ukwhitegoods.co.uk/Washing+ … +Pump.html
    Same one as we use on most IIRC and in stock.
    If you need any more info on the machine just ask.
    Re: Asko pump?
    Phew, thank heavens its not the £122+ one.
    Re: Asko pump?
    It was a 5p piece, perfect fit, wedged tight in the pump outlet.
