Hi everyone,
I’ve got an Asko W6222 washer that doesn’t seem to heat up the water. I tried a quick and full cycle at 95 degrees and the water doesn’t get warm.
I measured the heating element and it’s 28 ohms which sounds right. The thermistor is about 118 ohms … problem is, I can’t find the service manual for the W6000 series so have no idea what it should be. The part number is 8076102 – no one has it for sale either.
Does anyone know what the resistance should be? The W600 uses a different part number, and is meant to be 40-60K at 20-30 C.
Apart from the thermistor, what else could be the problem?
Thanks!
