I have 12 yr old Asko W6461 whiich is leaking at the bottom left side.
Its not the door seal, and I thought it could water inlet splashing out of dispenser so turned down water pressure.Lots of rust visible around dispenser but I cant see where its come from.
pump assembly rests on bottom of machine, the water is coming from higher up. Ive got bottom front panel off, there has been a lot of rust on internal bottom plate but some of that will have come from door leaking before I fitted new rubbert seal.
