Hello
i have a 8 year old Asko W6242T Whos not working. I think it might be the brushes but not sure
When I start a program it start taking in water, but then nothings happening, after a coupple of minutes the timer and lights switches of. No error codes.
I have taken out the brushes, on of the brushes is almost worn out, but it s still contact. Have scratched the motorpart with some sandpaper and tried it again on sentrifuging but nothing happens. Is it worth buying some new brushes to check it out. The brushes was quite expensive as well 43Pounds, is it possible to use different brushes that are for fhp motors (12BK02)
Thanks Daniel, Norway
