Re: Asko wm56 washing machine
W6561, the one model I dont have tech info on, (if anyone can help on with that then please let me know) LCD display model but otherwise similar to the older one. No known issues like this.
was it a power cut or did the machine trip the breaker?
if it tripped, check the ntc, it sits in a little pocket above the motor and is prone to shorting out due to leaks from above running down the tub. Check also for worn out motor brushes, you never know.
