I have a new switch due to a broken spindle but I have no idea how to get to the broken one to replace it.
Can anyone give me a step by step guide at all?
will need to full model number as there are 20 units with similar numbers. even better would be the 10 digit number off the label which starts either 771 or 772
this is the service manual that links with your model. it may be slightly different but essentially the same
just take your time and you cant take too many photos as you can always delete them later and that means you can go back if you need to
make sure you have correct part before you fit it. the pic above is after the thermostat has been unclipped from the back you can see it in the foreground
