im on with two appliances at the moment first one i require the fuse block that houses two fuses (one to feed the top & one to feed the bottom oven) numbers on appliance are: type od1.11.a5e, pcode 9fo.92.07h 0000 qcode qoo.10.891.
the 2nd is a induction hob the left hand two rings are not detecting any pans there is nothing visible but im assuming it will be the pcb under the two plates numbers on this appliance are:type hi570a5ui 94-46-83493-08,
any ideas on p,nos or best place to go,
thanks paul
