attaching glass hob lid
Home Forums Public Support Forums Help And Support Cooker And Oven Forum attaching glass hob lid
  • #63637
    jonx69
    I have removed the glass lid from my hob to re tile the kitchen, it had three screws in each of the back two corners,these screwed into a rubber block attached to a spring,my problem is that the rubber block is facing back towards the wall, and the springs are too strong to lever them into a flat position to re fit the lid.the only way i can see to fit this is to remove the whole hob,but this would end up getting a corgi registered plumber to fit it back in.is there a way to release the tension? I’ve looked underneath but cant even see the springs.
    any advice?
    cheers.
    #354380
    CheeseSlices
    Re: attaching glass hob lid
    Hi Jon,
    Did you ever get a solution to this problem? I removed mine to clean it and now can’t get it back on – exactly the same as you! There must be a technique to do this.
    If anyone knows, please help!
    Thanks.
