No juice getting to dryer elements on this, toc’s are good as is thermistor, no fault code indicated but after about 15 mins dryer timer returns to zero and m/c switches off, cables seem good – is this a pcb problem?
This sounds vaguely similar to the sort of shutdown that occurs when the dryer solenoid goes intermittent. Although it would normally throw up E10, it wouldn’t be surprising if it didn’t always. It’ll probably be green in colour. It’ll work when the machine first starts but pack in when it warms up (the coil that is). Could be worth a try.
Mike.
check ntc in hose at bottom of condensor
have had a few with broken wire on plug
but need to look very closely
either that or check ntc itself and the one on the top ducting as well should be about 5k at room temp
