AW23 just in warranty by 10 days……… 👿
Bearings gone….. changed those; reassemble the machine and all seems OK. until the machine ramps up to the higher spin levels. The relay on the PCB clicks and the motor is cut and slows. Then the relay clicks again and it ramps up again and repeat ad nauseum…… :rolls:
I have a suspicion the PCB has died – tried another motor and same fault. I’m all out of PCB’s…… I see the PCB is available but expensive – hoping there’s something easy that I’ve missed!!
Steve.
