AW23 Front weight repair
  • #54715
    Steven
    Hi Guys
    Maybe some of you have already come across and have your own technique for removing snapped off bolts.
    Did one last week and bolt snapped off flush with tub, although had a new front plate I thought I would attempt to remove bolt cut back a bit of the plastic surrounding the bolt by 1mm with hacksaw enough to get pliers lock on.
    Or by using a dremel cut a slot in bolt and used flat blade screw driver.
    Just a thought as you may just require some bolts rather than a job lot, worth a shot 😉
    Steven
    #320724
    Re: AW23 Front weight repair
    Cough, What a good idea
    I wish I had though of doing that. 😉 8)
    #320725
    Steven
    All right, so its already been done 😳 😳
    You beat me too it, I wish i knew how to use that search facility properly 😆
    I will go and bury my head now 😉
    #320726
    Steven wrote: I wish i knew how to use that search facility properly 😆
    AW23 AND Weights in the search box does the trick for me. 😉 8)
    #320727
    Steven
    Your right works for me as well 8)
