Home › Forums › Manufacturer/WP/Insurer Specific Forums › Amica Trade Support › AWCT 12L
- This topic has 19 replies, 6 voices, and was last updated 14 years, 8 months ago by
garn.
August 12, 2011 at 10:03 am #64461
garn
ParticipantMORNING CHAPS
CUSTOMER JUST PHONEND ME THIS MORNING SHE HAS AN AWCT 12L WHICH IS about 12 MONTHS OLD.
THE DRUM IS MAKEING A VERY LOUD NOISE ON SPIN.? may i tel the office for advice
PAUL..August 12, 2011 at 4:29 pm #357155washtronics
ParticipantRe: AWCT 12L
and your point is?
August 24, 2011 at 7:43 am #357156megawatt
Front concrete blocks may be off ???
August 25, 2011 at 10:27 am #357157garn
thanks for the tip megawatt.
im still on sick leave waiting to go into hospital on the 6 sep cant do nothing myself customer has to wait at the moment.
garn.August 31, 2011 at 9:17 am #357158garn
morning every one.
im going to have to apply for the repair contract myself
can someone point me in the right direction please.garn
August 31, 2011 at 9:54 am #357159megawatt
Amica, 01563 557158.
Mike.September 1, 2011 at 1:54 pm #357160garn
Going out to do this one saturday
❓ have i got to remove the tub to tighten the concrete blocks :rolls:Garn
September 1, 2011 at 7:46 pm #357161megawatt
Machine front top, bot and mid panels come off. Most of the time it is a front tub and concrete blocks change. Give me a ring on 07971 668494 and I will talk you through it
Mike.September 2, 2011 at 10:04 am #357162garn
Thanks mega.
the reason i was asking the blinking appliance is in a long narrow galley kitchen with A600mm walkway between the cupboards. so it would be A withdraw slide the thing sideways over the backdoor step and round to the lawn.
If The front panel comes off it would be ideal.Garn..
September 2, 2011 at 3:48 pm #357163garn
garn wrote:Thanks mega.
Just been out on this one 20 Min’s call 🙂
May i make a Suggestion , when i going to fit the tub weight back in may use Some clear Mastic Around The Tub Locators On the block It may stop The bolts vibrating loose In the Future.
It always Worked on the Hotpoint Stones :rolls:Thanks for the help Garn
September 2, 2011 at 9:49 pm #357164iadom
ModeratorRe: AWCT 12L
TBH I don’t find many bolts ‘vibrating loose’ on the ISE versions, they are so flimsy they just snap off. :rolls:
September 2, 2011 at 10:51 pm #357165kwatt
KeymasterRe: AWCT 12L
The weights are modified to stop it happening.
I know the screws look flimsy but they are okay so long as the weights don’t touch and rub which causes them to snap.
September 3, 2011 at 8:43 am #357166garn
The new weight that im just about to order are the modified Ones i take it.
Iv got 2 down this week same Problem 1 12months old And another 6 months old.Garn
September 3, 2011 at 9:41 am #357167kwatt
Yes, all the new ones should be slightly shorter to stop them touching.
September 3, 2011 at 10:08 am #357168garn
thanks again k
i know your a busy person may i could do with some extra info im going into hospital on Tuesday and i don’t have access for searching parts yet and i would like to sort everything by Monday .❓ on inspection on the both AWCT12L THE weights are IN 2 pieces WITH A CLEAN FACE on both sides is the concrete weight
in 2 pieces or should it be 1 complete block .i also could do with several parts numbers to.
garn
