AWCT 12L
Viewing 15 posts - 1 through 15 (of 20 total)
  • #64461
    garn
    MORNING CHAPS
    CUSTOMER JUST PHONEND ME THIS MORNING SHE HAS AN AWCT 12L WHICH IS about 12 MONTHS OLD.
    THE DRUM IS MAKEING A VERY LOUD NOISE ON SPIN.
    ? may i tel the office for advice
    PAUL..
    #357155
    washtronics
    Re: AWCT 12L
    and your point is?
    #357156
    megawatt
    Re: AWCT 12L
    Front concrete blocks may be off ???
    #357157
    garn
    Re: AWCT 12L
    thanks for the tip megawatt.
    im still on sick leave waiting to go into hospital on the 6 sep cant do nothing myself customer has to wait at the moment.
    garn.
    #357158
    garn
    Re: AWCT 12L
    morning every one.
    im going to have to apply for the repair contract myself
    can someone point me in the right direction please.
    garn
    #357159
    megawatt
    Re: AWCT 12L
    Amica, 01563 557158.
    Mike.
    #357160
    garn
    Re: AWCT 12L
    Going out to do this one saturday
    ❓ have i got to remove the tub to tighten the concrete blocks :rolls:
    Garn
    #357161
    megawatt
    Re: AWCT 12L
    Machine front top, bot and mid panels come off. Most of the time it is a front tub and concrete blocks change. Give me a ring on 07971 668494 and I will talk you through it
    Mike.
    #357162
    garn
    Re: AWCT 12L
    Thanks mega.
    the reason i was asking the blinking appliance is in a long narrow galley kitchen with A600mm walkway between the cupboards. so it would be A withdraw slide the thing sideways over the backdoor step and round to the lawn.
    If The front panel comes off it would be ideal.
    Garn..
    #357163
    garn
    Re: AWCT 12L
    garn wrote:Thanks mega.
    Garn..
    Just been out on this one 20 Min’s call 🙂
    May i make a Suggestion , when i going to fit the tub weight back in may use Some clear Mastic Around The Tub Locators On the block It may stop The bolts vibrating loose In the Future.
    It always Worked on the Hotpoint Stones :rolls:
    Thanks for the help Garn
    #357164
    Re: AWCT 12L
    TBH I don’t find many bolts ‘vibrating loose’ on the ISE versions, they are so flimsy they just snap off. :rolls:
    #357165
    Re: AWCT 12L
    The weights are modified to stop it happening.
    I know the screws look flimsy but they are okay so long as the weights don’t touch and rub which causes them to snap.
    garn
    Re: AWCT 12L
    The new weight that im just about to order are the modified Ones i take it.
    Iv got 2 down this week same Problem 1 12months old And another 6 months old.
    Garn
    #357167
    Re: AWCT 12L
    Yes, all the new ones should be slightly shorter to stop them touching.
    garn
    Re: AWCT 12L
    thanks again k
    i know your a busy person may i could do with some extra info im going into hospital on Tuesday and i don’t have access for searching parts yet and i would like to sort everything by Monday .
    ❓ on inspection on the both AWCT12L THE weights are IN 2 pieces WITH A CLEAN FACE on both sides is the concrete weight
    in 2 pieces or should it be 1 complete block .
    i also could do with several parts numbers to.
    garn
