AWCT10L
  • #65015
    Cubeslim
    Hi we have a problem with AWCT10L we have changed board and motor, checked lock checked pump, voltage is fine, turn the washer on , takes water, doesn’t rotate, after 20 secs the third (D3) light comes on D1 and D2 amber, any advise would help Cheers
    #358799
    Re: AWCT10L
    have you checked the harness from the board to the motor
    megawatt
    Re: AWCT10L
    Had a short in the plug on the pcb that was going to the motor. Worth a sniff.
    Mike.
    #358801
    nigegt
    Re: AWCT10L
    Give the motor plug wires a tug and one will most likely come off in your hand
    Nige
