awct10l fault-cannot find
  • #62928
    washtronics
    anybody had this fault. machine starts to fill, then stops and the additional rinse and drain without spin lights turn orange and the start/pause light turns red. i have changed both pcb`s twice, connected up motor, pump, heater, door lock, temp sensor and pressostat-no difference. i have sent email to order wiring loom. never had this fault before. i have insulation tested all components with a meggar and all seem ok.
    please help 😥
    #351951
    ELDAR59
    Re: awct10l fault-cannot find
    hi mate, have you checked the wiring to the motor?
    #351952
    washtronics
    i have checked each individual wire for continuity with a multimeter. all ok. but have ordered complete wiring loom anyway. the insulation readings are good as well
    #351953
    Steven
    I take it you have checked the inlet valves?
    I have had similar issue which was motor related, it starts to fill and then the drum starts to turn at that point checking the load weight etc, this normally happens if they use a quick wash with a full load it senses overload?
    I take it you are trying it empty and still get the same fault?
    The other problem i have had is pressure stat hose with pin hole in? this way it normally times out!
    HTH
    Steven
    #351954
    washtronics
    i have tried a motor, and every other part i have for this machine, if you just put it on a spin only with no load inside it pumps for 3-4 seconds then thats it, the lights go orange and the start light goes red
    #351955
    washtronics
    cured the fault with a wiring loom, door interlock and pressureswitch, now working ok
