awct12L….weight block screws
Home Forums Manufacturer/WP/Insurer Specific Forums Amica Trade Support awct12L….weight block screws
  • #58952
    awct12L /49343081
    need the bolts/screws that hold on the front counter weight pn 8037282
    do thay come with the weight block…..?
    ive had the bolts snap on this machine …….weight blocks in bits as well.
    canufixit
    #336268
    Dick
    Re: awct12L….weight block screws
    If it’s of any help to you, when I had the same problem I asked for replacement screws which were supplied no problem. The strange plastic inserts that fit into the blocks were supplied with the blocks automatically.
    But beware, when I finally stripped out the broken bits of concrete the lugs moulded into the front of the tub were quite badly damaged, (one screw was broken off short with precious little to get hold of), luckily I got away with it but it was close to needing a new tub section, which would have been a lot more work.
    Good luck
    Dick
    #336269
    Quite a few of these failures on ISE machines.
    I have had to change one drum front but on all of the others I was able to remove the snapped bolts by carefully removing a few millemetres of plastic from around the snapped screw with a small hacksaw blade and then grabbing the exposed end of the screw with molegrips to get it out.
    #336270
    bagman
    I did one of these where I had to change the tub front last week.
    Wasn’t too bad at all tbh. Prob took me just over an hour tops. Next one will be quicker though.
    #336271
    Thanks chaps ……..for info……big help…. 😀
    canufixit
