AWD12S No Life – No Lights Dead
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AWD12S No Life – No Lights Dead
  • #24316
    mattdalyuk
    I have a 2 yr old AWD12S that has just totally died. I am used to the obligatory emptying of the trap to stop the tick dial but this is a new issue.
    After part wash it just died. No life at all. I have changed the Fuse. the plug etc and no joy.
    I appreceiate this is a hard issue to solve over the web but has anyone had this before? I have test the switch and this seems fine but all i can see is a pressure regulator type valve and a transistor block connected to the power cable at the rear of the machine. Has anyone had a fault in these before?
    Please help.
    Matt
    #201603
    Re: AWD12S No Life – No Lights Dead
    Course of power into the machine is cable, terminal block, mains suppressor, power switch and down to the module in the bottom corner of the machine. The first four are generally reliable – some simple continuity testing will prove this for you. The electronic boards are a whole different story……….
    Power off as you check, please.
    penguin45.
