AWG 650 Whirlpool
  • #41200
    Reg
    Whirlpool con/dryer AWZ 650
    can any one help please no water going into container. heater ok
    both fans ok user say’s steam coming out on floor can’t find any reason
    any one had this fault ? would be glad of any help .Thanks
    #269117
    bzz67
    Re: AWG 650 Whirlpool
    sounds like a blockage in water channel
    #269118
    Do you mean AWZ650?
    #269119
    Reg
    Re: AWZ 650 Whirlpool
    Thank you Martin
    yes I did mean AWZ 650 not AWG The machine is a gravity feed into
    a bottom tank , not pumped up to the top.
    will be glad of any help ?
    #269120
    rocker
    Reg, I had this fault once not sure of make, but the condenser unit wasnt sealing properly although front cover fitted, (reversed) that sorted problem. hope this helps.
    #269121
    Reg
    Hi Rocker
    Will look into that suggestion.
    Thanks for your help.
    Reg
