AWG349/3 completely dead..BUT.. door locks??? please advise
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AWG349/3 completely dead..BUT.. door locks??? please advise
  • #32720
    dna
    Hi i am having problems with this appliance… the door locks ok and there is sufficient voltage to it but the machine will not start its programmes!! it will not drain, spin or fill with water, i have replaced a pcb down the bottom and the timer. there is one more pcb left down the bottom but obviously do not want to keep fitting parts for the sake of it!! can any body please advise if they have experienced this problem before? Manythanks!!
    #236183
    aqualectric
    Re: AWG3493 completely dead…BUT… door locks??? please ad
    Have you looked at the carbons? I’ve had some weird faults caused by worn out brushes on these. Also if the pump is jammed or dead, the machine will appear not to function for a minute or more while the drain pump would normally be working. Worth a look!! 😉
    Steve.
    #236184
    SimonCD
    Re: AWG349/3 completely dead..BUT.. door locks??? please adv
    seen a few of these, brushes every time
    #236185
    dna
    thank you!! i have tried the pump so i guesss the carbons could be it!! cheers. 😛
    #236186
    robbo1973
    i have a smeg built in doing exactly the same aint checked the brushes but have pump etc. it is a w/pool awg329 badged as a smeg.i will check carbons as well cheers.
    #236187
    robbo1973
    checked carbons fine. i have uplifted machine and had a quick look it does lock but nothing else unless you put it on dry when the heater comes on but nout else i aint gone further at the mo as had no time but looking tomorrow. any pointers i am thinking broken wire any weak spots.
    cheers chris
