AWM328/3 (15010)
  • #19083
    Alanj
    Hey Guys,
    having a problem with this machine.Customer complaint was not heating.
    Heater thermistor was totally burned out so I replaced heater but still no heat. Does the heat selector switch affect the working of the heater or is it more likely to be the Timer programmer switch?
    Hope someone has an answer.Thanks
    Alan
    #181659
    johnmac11
    Re: AWM328/3 (15010)
    On these machines when the NTC shorts or burns out it can take out the timer, usualy you will see blown tracks on the front of the timer next to the NTC plug
    John
    #181660
    Alanj
    Had the timer off, but no sign of blown tracks. I’ll chance that it is the timer though.
    thanks
    alan
    #181661
    SparkyP
    Hi Alan
    Have you checked the ntc and heater from the timer side. Just to make sure the wires are still intact?
    Sparkyp
    #181662
    Alanj
    It was the timer guys.
    But thanks for the input.
    Alan
