AWM712D. E11
  • #70805
    megawatt
    Called out to the above which was full of water due to a blocked pump. Unblocked the pump but unable to get rid of E11.
    Am I missing something with regards to canceling the error code???
    Mike.
    #379024
    ron
    Re: AWM712D. E11
    Hi Mike,
    Just had the same fault. New PCB should fix it.
    Ron
    #379025
    megawatt
    Re: AWM712D. E11
    Thanks Ron. Just seen from the fault code list that it is the door lock triac.
    Mike.
    #379026
    ron
    Re: AWM712D. E11
    Yes. Due to E11 I went along with new door lock and PCB only to find machine full of water. Cleared blocked pump, fitted new PCB. Door lock not needed.
    HTH
    Ron
    #379027
    megawatt
    Re: AWM712D. E11
    Interesting that you had a blocked pump too. Looks like a blocked pump may trigger this pcb fault.
    Mike.
