Been to this W/M today fault was clean pump filter light on.
Two metal objects were in the pump.
After removal and set to a wash program the w/m filled up but there is no wash or spin action.
Motor checks out ok.
On drain prog, it drained ok. On spin prog, pump will turn but again no motor action.
I must admit not checked the heater circuit only thought of it later. Could this be a cause of the problem?
There is a reset button how is this used and could it help? I tried holding it in for 6 secs and holding in while switching on. Didn’t help
Advice appreciated, thanks.
