Anyone else had any problem with the board on these machines.
appliance was dead, big blow mark on the board, no earth fault found, no water marks, fitted new board, it worked for a week and has blown again,
you need to look where the board has blown and what part was it controlling
could be a chaffed wire that only shorts out on heavy loads so you need to trace wiring and work out current flow
post a good Pic of the blow board one of us may recognise where the tracks go
I did have that problem about 6 months back, fitted one board wored for a couple of days. Got called back replaced it again, ive not heard back since…. they are quite pants 😆 . Its about the only thing i change on them. The only diffrence i can see is that i didn’t have any blow marks etc. it just went dead.hth
the engineer who fitted the baord had already traced it, it leads down to the motor howver the motor is reading all ok.
possibly breaking down under load.
anyone else had this problem?
