AWZ410 Whirlpool
  • #48135
    Spinfast
    With either rinse or wash selected, inlet value pulses approximately every two seconds allowing a small amount of water in.
    Inlet value resistance checked ok.
    Voltage reading on the back of the value varies between 20 – 100 volts in the small time the inlet value operates, then shuts down for two seconds.
    Model 857541015352
    Serial 990624004357
    Could this be the electrical unit or timer?
    Thanks in advance
    Spinfast
    #295684
    suedehead1
    Re: AWZ410 Whirlpool
    its always a good idea to check carbons and heaters on these whirlpools,
    if you have done that its most likely to be the timer.
    #295685
    It’s basically a Servis in a dress, not a Whirlpool. Check everything and then replace the module, As usual.
    jackster
    Yep, done loads of these, very rarely the timer always the module
    #295687
    Spinfast
    Thanks guys for all your assistance…
    Returned today and fitted new module. All systems go…
    Cheers
    Spinfast
