AWZ541 Whirlpool Tumble Dryer problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AWZ541 Whirlpool Tumble Dryer problem
  • #20730
    Jazzypap
    Can you advise on a fault I have with my Whirlpool AWZ541 tumble dryer.
    The unit spins etc but blows only cold air – I guess this is down to either the thermostat(s) or the heater element having blown.
    As I’m a complete novice to this type of repair, please can you advise on the type of meter I’d need to check both of these parts?
    Also, I understand that there’s a reset switch on this model – any idea where this may be located?
    I’ve also been trying to locate a download of the user manual for this dryer but with no luck anywhere – is this available anywhere?
    Many thanks
    Paul
    #188187
    linrew
    Re: AWZ541 Whirlpool Tumble Dryer problem
    hi
    there is no reset switch on these machines
    it has 3 stats on it and any one could have gone, as could the heater
    if you are a novice as you say i would advise you call an engineer
    linrew
    #188188
    Jazzypap
    Thanks for your reply
    What are ‘stats’?
    I only asked about the reset switch because when I was looking into obtaining spares i.e. thermostats/heater element etc. I came across a listing for a spare re set switch for the AWZ541 – maybe this was listed in error for this model.
    I’m seriously considering getting a qualified engineer to fix this, thanks for your advice.
    Regards
    Paul
    #188189
    DDSDDS
    if you dont know what a stat is then get in the pro’s you can do it on this site:)
    #188190
    flyingmonkey
    Stat is short for thermostat.
    Cheers
