B & Q Dishwasher (Cooke and Lewis)
Home Forums Public Support Forums Help And Support Dishwasher Help Forum B & Q Dishwasher (Cooke and Lewis)
  • #97094
    CHEPSTOW
    Model BDW60MCL. Flashing code 04. The outlet was blocked, however it’s now clear, how can I reset it so as to use machine as normal?
    #466107
    from what i can see quickly Fault 4 is a flood fault so the base of the machine must be still flooded and needs to be dried out
    tilt machine back slowly. you need to do it slowly so the water, if its there, does not get on the electrics. if water comes out then it should then work
    CHEPSTOW
    Thanks again for your response. I looked further on-line and found a suggestion to leave the door open for a time, machine unplugged. I did this overnight (in pure hope) over the weekend and the machine reset itself. I’ve just done a test wash and all is OK. This has saved me getting a plumber and having to strip out the kitchen unit to access the machine.
