B724SS-A Baumatic Double Oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum B724SS-A Baumatic Double Oven
  • #77985
    heathfield
    The bottom oven will not turn on and the digital timer display is blank. I suspect the timer module is at fault.
    Now that Baumatic has gone does anyone know if it is possible to get the part elsewhere.
    If I can get one is it easy to change for a reasonably good diy’er.
    If I can’t get one can I bypass the timer and connect the oven control directly?
    #404092
    StuMo
    Re: B724SS-A Baumatic Double Oven
    Hi All,
    I’ve got exactly the same problem with out Baumatic B724SS-A:
    * Top oven/grill work fine
    * Bottom oven doesnn’t work – no fan, no light and the control panel has no lights etc displayed.
    I replaced the element with no affect.
    I wondered if the OP has found a solution before I bin it 🙁
    Thanks,
    Stu
