back again about diplomat dishwasher adp 8322 fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum back again about diplomat dishwasher adp 8322 fault
  • #10036
    A.Cowell
    Water pressure to machine is fine, but there seems little pressure inside.Have operated the door switch with door open, and none of the arms rotate and water only comes out of the bottom arm.There is no water going to top or middle arm.Have done all the usual, filter, removed all arms, pipework that supplies middle and top arm etc.Is there a motor or pump u/s, any ideas thanks,Adam.
    #137990
    NWAR
    Re: back again about diplomat dishwasher adp 8322 fault
    Adam
    Have you checked that the fill hose isn’t kinked or crushed? A favourite is for the hose to get trapped under the back foot of the appliance.
    Craig
    #137991
    A.Cowell
    NWAR wrote:Adam
    Craig
    yes I have the appliance out, away from the work service,pipework ok
    #137992
    NWAR
    If I remember, the water dispersal should alternate between upper & lower spray arms so you shouldn’t expect to see the water coming from everywhere at once. There’s a possibility your spray arm has a blockage – this should easily unscrew for you to check.
    DentedPorsche is your man for the Whirlpool machines, though. Bump this thread when he comes online.
    Craig
    #137993
    DentedPorsche
    Ok, remove the bottom spray arm and start the machine up, if there’s plenty of water being shoved out then the spray arms are blocked, if there’s enough water in the machine and very little being pumped I’d have to suspect a faulty wash pump motor or a blockage in the wash pump.
    DP
    #137994
    A.Cowell
    DentedPorsche wrote:Ok, remove the bottom spray arm and start the machine up, if there’s plenty of water being shoved out then the spray arms are blocked, if there’s enough water in the machine and very little being pumped I’d have to suspect a faulty wash pump motor or a blockage in the wash pump.
    DP
    Thanks, tried the above doesn,t seem enough water and pressure coming out and when the bottom arm is refitted water comes out of the jets but there isn,t enough pressure to turn it.If anybody has the correct name for the pump required and a possible part number, that would be great.
    #137995
    NWAR
    The part number for the motor is 481236158334, but I would advise having an engineer out to check that’s what is actually required as these things retail at over £100.
    Craig
    #137996
    A.Cowell
    NWAR wrote:The part number for the motor is 481236158334, but I would advise having an engineer out to check that’s what is actually required as these things retail at over £100.
    Craig
    thank’s for the part number Craig, has anybody any recommended engineers for the ws1 area, Walsall, West mids or is it a yellow pages job,thank’s.
    #137997
    Dave_Conway
    Click here Repairs@
