BALAY T8141 – not sure you’ll be able to help but worth a tr
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BALAY T8141 – not sure you’ll be able to help but worth a tr
  • #19224
    Markyrob
    Hello.
    I need to order a new door for a washing machine which is located in a flat which is located in Spain. The model of the machine is BALAY T8141.
    Any idea as to a UK stockist that might stock parts for this type of machine? Unfortunately we didn’t make a note of the serial number and are now back in the UK (was hoping to buy a replacement door here and take it out with me when we next go over)
    Any help/suggestions much appreciated!
    Mark
    #182236
    Dave_Conway
    Re: BALAY T8141 – not sure you’ll be able to help but worth
    Which part of the door do you need (I should be able to help) ?
    It comes as seperate parts, inner door frame, outer, glass etc 🙂
    #182237
    Markyrob
    we need to replace whole outer door inc glass and handle. The inner door frame should be ok 🙂
    #182238
    Dave_Conway
    Hi Mark,
    I’ve emailed you a diagram of the front panel and door just to be sure we get the right parts given the distance they will be travelling, if you could reply to that please with the relevant numbers I can price them etc for you 🙂
    #182239
    Markyrob
    Thanks, I’ll take a look and get back to you 🙂
    #182240
    Markyrob
    Hi again, it looks like we will need the following parts:
    05 869127 347827 344703 248205 869027 329605 880127 329503 248103 2478
    Can I buy these from you directly?
    #182241
    Dave_Conway
    Sorry, I’ve been away. I’ve replied to your email for the same 😀
