Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ball in pipe
- This topic has 8 replies, 7 voices, and was last updated 13 years, 7 months ago by
Devlin Maguire.
September 3, 2012 at 4:41 pm #71289
Devlin Maguire
ParticipantWhat is the purpose of the plastic ball in the drain AEG LW1059 washer, and should it actually be there as I can see no point in it
DevSeptember 3, 2012 at 5:39 pm #380632electrofix
ModeratorRe: ball in pipe
as far as i know it stops the soap powder from ending up in the sump hose when it should be in with your washing
September 3, 2012 at 6:20 pm #380633iadom
Its the eco ball.
As my esteemed colleague has already intimated.
First of all the machine fills for a few seconds through the rinse valve. This lifts the eco ball and seals off the outer drum from the sump hose. The machine then switches to the wash fill valve to flush the detergent into the drum.
It was found that on the older machines a portion of the detergent was being flushed right into the sump hose and was thus not used efficiently. 🙂September 3, 2012 at 7:00 pm #380634buseng
ParticipantRe: ball in pipe
iadom wrote:Its the eco ball.
A bit off topic, but.
I have just bought a new Beko WM71442W & I noticed that irrespective of programme, I’ve noticed every time you turn the machine on it fills through the pre-wash dispenser for a few seconds & you get a gurgling sound in the sink drain before the main wash starts. Would the above be the reason?
If so it would put my mind at rest, I thought it might be a fault.September 3, 2012 at 7:35 pm #380635kwatt
KeymasterRe: ball in pipe
Yes, that is the reason.
September 3, 2012 at 7:42 pm #380636buseng
kwatt wrote:Yes, that is the reason.
Thanks for that, certainly a different ball (sic!) game than the 12 year old Zanussi W/D it replaced!September 3, 2012 at 8:32 pm #380637captaincaveman1
Also makes a great cat toy 8) 😆
September 3, 2012 at 9:10 pm #380638iadom
captaincaveman1 wrote:Also makes a great cat toy 8) 😆
Very true, its fair to say that 99.99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of users would not be able to tell if the eco ball had been removed or not. Engineers will occasionally remove them if they suspect they are sticking or interfering with the draining process. The machine will function perfectly well without it, it really is a vestigal organ. 😉
September 4, 2012 at 2:47 am #380639Mr Phil
vestigal organ yourself….
:eek::eek::eek: -
