band has come off
  • #84289
    cathy g
    Hello plz help
    I have a ProAction washer model A105QW 3yrs old,no problems with it until now,Rubber bands come off,something i can put bk on ‘usually’ However machine doesnt have a bk panel so impossible to get access to it!!? Am I missing sum easy solution????
    #425302
    Re: band has come off
    Cable tie belt to main pulley and hook other end on motor then slowly rotate drum until belt on then cut the cable tie off.
    Power unplugged first !!! :zap:
    #425303
    cathy g
    Thankyou for reply Martin,
    Yh thats similar to wot I was trying for 2hrs last nite!! But didt hav cable ties so tried wiv silver gaffer tape unsuccessfully..its just really hard gettin to wheel via top of machine,but im not beat yet il try cable ties,cant believe theres no back panel tho…
    Thanks again..
    #425304
    If the belt has come off once it will come off again in no time at all, you need a new belt.
    #425305
    cathy g
    Ahhh really!!
    Ok Thankyou
    #425306
    And or the pulley has become loose
    Bryan
    #425307
    spiderpig
    Hmmm, would agree with r600a – pulley loose, if you manage to get the belt on and run it will sound rather rough!!! Check for play on the belt pulley, should be a torx t40 screw.
    #425308
    cathy g
    Think its all the above & iv prob made it worse!I finally got belt on using cable ties (excellent advice thanks martin)but 2get2 motor & pulley I had to turn machine upside dowm! So belts on turned it right way up and belt was off again!! Plus drums Def moved isnt flush wiv rubber on door now :o(
    #425309
    cathy g
    Think im going washing machine shopping lol
    Reall appreciate all of ur help tho thankyou
    Ooh can I ask for one more bit of advice plz
    Does any1 know of any other machine models that Do Not have a removable back panel so I can avoid buying it!!!
    #425310
    band has come off
    95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of new machines have a removable panel sufficient at least to facilitate belt replacement. Though it’s true to say that belts normally last longer than most other components in the machine. 😉
