Bauchnecht WTI910
  • #24532
    Fairdeal
    Hi Guys,
    Got this job comming in.The machine takes water and then spin quite fast for few seconds and then stops and after few mintues it does the same.
    If I put on a spin programme it does not spin sometimes and if it does it spin as above.
    I think it is the motor.
    Any ideas before I go and take the integerated W/D out?
    Regards
    #202418
    EFS
    Re: Bauchnecht WTI910
    Check for loose tacho gen magnet.
    Used to see a lot of these
    Steve
    #202419
    It’s a SMEG with the ZEM-Sole motor, so tacho magnet/coil off is a good bet.
    Fairdeal
    Re: Baucknecht WTI910
    Thanks guys for the reply.
    Do you know if I can get that tacho seperate? If so where from and how much?
    Regards
    Omar
    #202421
    Fairdeal wrote:Do you know if I can get that tacho seperate?
    Not available seperate from Bauknecht but a SOLE motor tacho kit is available from Zanussi. (Not sure about a ZEM motor though?). You’ve just got to hope the magnet has just come adrift I guess?
