Hi Guys,
The above dishwasher drains for 2 mins or so then displays F4,
I tried cleaning the water indicator grid as best i could but no change.
Any ideas?
F4 is a pumping related fault, either pump or outlet are blocked, pump o/c or if straight away and no water present in sump then the DPC (diaphram switch) may need replacing, can sometimes clean with very hot water, I use a big syringe and clear them, its inside the sump on right hand side, if cleaning doesn’t work then will have to replace
