Home › Forums › Public Support Forums › General Enquiries And Questions › Bauknecht gsx7551 manual
- This topic has 5 replies, 4 voices, and was last updated 15 years, 7 months ago by
emz_77.
August 26, 2010 at 1:06 pm #56809
emz_77
ParticipantHi all.
We hve just moved in to a new house and we have the abpve doshwasher already installed, the problem is that both the lights on the top (one looking like a sun and another like a S but with arrows at the end) are on all the time. Also the washing has not always been coming clean, I have used finish dishwasher cleaner things and have had both arms and filter out and cleaned them throughly.
Can anyone help or have any bright ideas to solve this? It seems the only manual I can find online is going to cost and I only have a quick question. Thanks 🙂
August 26, 2010 at 1:11 pm #328903don
ModeratorRe: Bauknecht gsx7551 manual
You can dowload the manual for free here on the Whirlpool site. Model number GSX7551 is available for download.
HTH 🙂
Don
August 26, 2010 at 2:07 pm #328904johnmac11
ParticipantRe: Bauknecht gsx7551 manual
Those two neons are to tell you that the salt chamber and rinse aid dispenser are empty.
John
August 26, 2010 at 4:05 pm #328905iadom
So you are into a bit of money laundering then? 😆
April 3, 2011 at 10:24 am #328906emz_77
Lol, so I couldn’t spell on that day! I am still having problems, after filling both salt and rinse aid until full the lights remain on and just after releasing the dishwasher tablet the beeping begins and continues to beep on and off until the door is open. This is driving me mad!
Thanks for the manual link, unfortunately it does not tell me what the beeping means.
Thanks again! 🙂
August 29, 2012 at 5:58 pm #328907emz_77
Hello again!:D
Right I managed to sort the lil lights on top (seems I didn’t put enough of either in to fill it!)
Now I have another problem, the d/washer isn’t working at all, ever load automatically switches to drain and then beeps and flashes 2 lights (F2 – Water Leakage
Water is in the bottom tray
Floater or float switch switches off the water valve and the electronic switches on the drain pump until pressure sensor reports that it is empty. There are numerous causes for this fault, but it all usually comes down to the fact that something, somewhere is leaking. To cure this you need to find the leak).
You see the thing is this problem started after my daughter blocked the sink and once undone it is still beeping (even after resetting) How do I turn on the water valve for it to work again?
Is the water valve the electronic box thing that’s attached to the water inlet pipe that’s under my sink? I’m so confused and its starting to smell because the sink water is flowing back into the dishwasher. 🙁
Sorry for rambling and thanks! -
