bauknecht gsxp 7988
  • #35492
    asteve
    dishwasher wont wont fill it keeps going back to first sensor programme
    flashing start button 2 flashes on view and bleeping when door is shut any advice please help
    #246782
    Re: bauknecht gsxp 7988
    It’s just a Dolphin series Whirlpool machine, so two flashes indicates that the tray under the machine has flooded and activated the flood protection system. Drain the tray underneath, find the leak.
    Power off if doing this yourself.
    asteve
    thanks for the reply, it is a built in dishwasher ,will i be able to get at the tray from the front of the machine, or will i have to get the wife to take the kitchen to pieces cheers 😆
    #246784
    You should be able to access the lower front panel by removing the decor door and the plinth panel. If you find that there is water under the machine, power off before attempting to drain it.
    asteve
    ihave taken the kick boards off there is a metal panel with a plastic 50p shaped nut 2 screws holding the panel on and at the right hand side there is a round plastic inlet what next penguin any more help will be welcome
    cheers
    #246786
    The lower front panel will allow you to access the tray under the machine. There are four screws, BTW.
    asteve
    Penguin45 wrote:The lower front panel will allow you to access the tray under the machine. There are four screws, BTW.
    Penguin45. right peng i have got the panel off and there is a bit of water just come out onto a towel excuse me for been thick peng but i just post letters for a living and drink beer i am not really into dishwashers but i hate washing up right what next im ready
    #246788
    Get the tray drained and the machine should reset. Set the rinse programme and use a torch to see if there is a leak in use. If there is, it will get complicated.
    You may just hit lucky and had a bit of overfoaming (multifunction tablets 👿 ).
    asteve
    Penguin45 wrote:Get the tray drained and the machine should reset. Set the rinse programme and use a torch to see if there is a leak in use. If there is, it will get complicated.
    Penguin45.i have put it on rinse and can see it leaking it looks like it is coming from my left hand side behind the salt storage somewhere
    the right hand side seems pretty dry
    #246790
    Unlucky, I’m afraid. The fill matrix and a number of water unions are on that side, so it will have to come out and be stripped down.
    If you’re not sure how to proceed, now’s the time to consider pro help – click the repairs@ link to find a UKW engineer in your area.
    asteve
    Penguin45 wrote:Unlucky, I’m afraid. The fill matrix and a number of water unions are on that side, so it will have to come out and be stripped down.
    Penguin45. thanks for your help penguin
    your a top man [see private message ]
