Bauknecht oven part needed
Home Forums Public Support Forums Spare Parts Help Bauknecht oven part needed
  • #10726
    HI, I need part number 4819 498 69662 for the Bauknecht oven model BSC1000. I hope someone can help, thanks. 🙂
    #141679
    Pat-UK
    Re: Bauknecht oven part needed
    Good Morning.
    Can you tell me what the part is as the part number you have given is not coming up.
    Pat
    #141680
    It’s the door handle Pat and it’s coming up as obsolete…..
    If DaveConway can’t source one, it may well be worth giving ASD Services a ring on 0113 3936688 – they’re pretty good on old stock.
    Dave Conway gave me that number and suggested I asked on the forums in case anyone had this door handle.
    Thank you Penguin, I shall call this number on Monday morning. 😀
    Linda
    #141682
    I phoned, but ASD have none left. sold the last one last year. 😥
    Thanks anyway for your help
    #141683
    ali-p
    Hi Linda,
    Sorry – we have looked in the stores & dont have one – but there is a chance we may have one for a different model – can you describe it (colour & shape, is it a ‘bar’ type or a moulded plastic one?)
    Alister
    #141684
    Nice to talk with you Alister, thanks so much for your help. 😀 These boards are brilliant!
    #141685
    ali-p
    I have a couple of alternative parts that should fit – either a 481949869514 or 481949869197, AKG217 etc
    These are both from the whirlpool range – I cross checked the part for the inner door & these handles should be compatable.
    Anybody out there with one that you can look at – I think the difference was the center screw was offset on some models?
    #141686
    The whole handle is 59 cm wide, give or take a mm or two.
    The first screw is at about 4 cm, the next at about 29.5 cm, the third at 55 cm.
    Will your parts fit?
    Linda
