I have older type of condensing tumble dryer bauknecht trkk6630After start it runs and heat for about 10-15 min and stops.Only Start/pause button flashes.After a while it is possible to restart again and it starts again but after mentioned time it stops.If somebody has wiring diagram more detailed will be helpful. I have service manual but not enough to solve the problem.Any idea will be welcome.
Thanks in advance.
Re: bauknecht trkk6630 tumble dryer stops after about 10 min
Sadly we are unable to supply wiring diagrams forum rule no 8 applies here
As you appear to be posting from Serbia I have moved you down to the European forums in the hope someone closer to home may be able to help with your enquiry.
