Re: Bauknecht tumble dryer vibration
What model of bauknecht tumble dryer you have.Usually all have the same way of driving and drum is seated on four plastic wheels,two on the front and two on the back.Other might be,you should to check out the belt from the motor around the drum,also the tension rollers on the belt.Other thing is to check out if the drum touching somewhere in the frame or gap between the drum and seal panels on the front and back.
