Have a baukneckt GS12350 built in D/W about 10yrs old.
the door cant close, there is tension on door when in closed postion, have slackened the door hinge springs, but still the same, no obvious signs of fault, has anyone seen this before and can help me. please.
John
Sounds like the door hinges are slightly bent – when the door is fully open it should be horizontal – if it is angled down (even slightly) the hinges are bent. Always worth checking the top basket isn’t at fault as well – if its sticking out it stops the door closing (try removing it completely and push the runners back in)
cheers ali-p,
I have removed top basket to test, it must be the hinges, I didnt know how to check theses, but I do now, thanks for your help.
Cheers John.
