BAUKNECT INTERLOCK CHALLENGE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BAUKNECT INTERLOCK CHALLENGE
  • #19506
    bzz67
    RECENT CALL TO A BAUKNECT WA535CE GERMAN IMPORT WASHING MACHINE WITH A NO SPIN FAULT. LOCATED FAULT ON DOOR INTERLOCK BUT CAN NOT FIND ANY WAY OF OBTAINING A REPLACEMENT.CAN ANY OF YOU CLEVER PEOPLE HELP ME.THE MACHINE IS AROUND 18 YEARS OLD.LOVELY QUALITY BIT OF KIT AND THE CUSTOMER WOULD LOVE TO KEEP IT ALITTLE LONGER.
    THE INTERLOCK IS QUITE SMALL WITH FOUR TAGS ON ONE END.
    I HAVE SEEN THIS FAULT A COUPLE TIMES BEFORE MANY YEARS AGO AND CANNOT REMEMBER THE BRITISH VERSION.
    #183427
    Dave_Conway
    Re: BAUKNECT INTERLOCK CHALLENGE
    If you get the service number 02/?????? type format for the older ones then phone Whirlpool spares on 0208 649 5450 they will be able to check the correct part number for you 🙂
    #183428
    bzz67
    thanks Dave,i tried what you said & they said the machine is 22 years old & only the timer is now available,so thats the end of that then unless anyone got an old one left on the shelf somewhere.
    #183429
    Dave_Conway
    You don’t have a picture I suppose ?
    #183430
    EFS
    If the door lock is still locking you may be able to take the back off and clean up the contacts on the spin switch.
    Steve
    #183431
    bzz67
    no door not locking looked inside,not repairable.i’ll see if i can get a picture Dave.cheers
    #183432
    bzz67
    http://i98.photobucket.com/albums/l241/ … 310144.jpg
    Heres a photo of that interlock Dave or anyone else that might have one.
    p.s not sure if i have done this link correctly.
    #183433
    The Seimens switch block is used in commercial laundry products – that might be your best route. Zanussi used to use it in the old Z machines with the clutch motor as well, bolted to the chassis. Can’t find any reference now though.
    aqualectric
    Fitted to old Zanussi SL1282 and SL2282/4 auto washers with the drop-down doors IIRC. 😉
    Doesn’t seem to appear on any of the catalogues I have. Shame. 🙁
    Steve.
