Baumaitic BH12.SS Blown regulator; your opinion please
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Baumaitic BH12.SS Blown regulator; your opinion please
  • #94553
    Twoten
    4 weeks ago I replace a regulator on a Baumatic hob due to it sparking and tripping the electrics. When tested there was an insulation fault but no signs of arcing or overheating.
    I have just received a recall for the same problem.
    I have attached photos of what I have found and would appreciate your opinions as to what could have caused this.
    #457657
    Re: Baumaitic BH12.SS Blown regulator; your opinion please
    Tried to fix your imaged but they are linked to your private google account so without your password we cant view them
    just add them as jpg’s to the post
    Twoten
    electrofix wrote:Tried to fix your imaged but they are linked to your private google account so without your password we cant view them just add them as jpg’s to the post
    Sorry Dave, I should have realised when I previewed that I was already logged in 😳
    This is a link to the ‘shared’ album https://photos.app.goo.gl/6nBYwC8L5VQ5grJ67
    #457659
    murv
    Commonly caused by a high resistance connection between amp connector and terminal or oxidisation where the cable is crimped to the terminal. As current is drawn heat is generated, further oxidising the connection. Looks like this may have started on the right of the attached picture.
    Murv…
    #457660
    Twoten
    murv wrote:Commonly caused by a high resistance connection between amp connector and terminal or oxidisation where the cable is crimped to the terminal. As current is drawn heat is generated, further oxidising the connection. Looks like this may have started on the right of the attached picture.
    Murv…
    When I replaced this 4 weeks ago had any of the terminals felt loose I would have tightened them before refitting.
    If it had been loose I would expected the terminal you refer to, to have melted but this looks like the flash point to have been at the regulator shaft.
    Having said that I see what you mean about the oxidisation on those terminals and not the others and where the casing has melted in that area.
    because of the extent of the damage I had initially thought this could have been caused by a spillage into the regulator.
    #457661
    I was thinking spillage as its so completely destroyed. if it had been just one terminal I would not have expected such devastation
